The linking back up of the map wire is all that matters.
cutting red and black wire on the fcd aswell as the above makes the job complete.
you then afterwards as a consequence will need ure afrs setup again.
your bad luck and problems could have been avoided if you had had the "insurance" that an afr guage can give.
do ureslef a favour and get one.they are only 150 quid. You need to be aiming for 10.7 afr as a super safe afr dude. Have run this for two years now and perfectly fine.others will say its to rich which it is but its safe as it adds extra cooling to the charge no matter how nominal.
best of luck
The way mine was connected with male and female connectors so for example there is black, red and yellow cables going to the ecu i just removed the parts and connected the colours back to stock again 2 mins you will have it done. I was shitting it myself but the car is going fine after removing it
