Lew91 Posted October 12, 2014 Posted October 12, 2014 I'm looking to run an internal fuel tank with swirl pot etc but don't really know as much as I should about it yet. I did google a few diagrams to see how it should be done but I could only find this one that really only made any sense to me Now my questions are 1) where do I put the swirl pot? I'm guessing after and before the return to and from the tank? And2) will I need to run 2 pumps? Ie: one in the tank? Cheers in advance Quote
Stu Posted October 13, 2014 Posted October 13, 2014 Run the standard tank outlet (from factory intank pump) up to the swirl pot, then run from the bottom of that tank to your new external pump which will feed the fuel rail. The return from the fuel rail will then run into the swirl pot and lastly you'll have another line from the top of the swirl pot back to the tank. Quote
Lew91 Posted October 13, 2014 Author Posted October 13, 2014 Yeah I have seen it done like that, did a fair bit of looking in to it last night and I think I've got it sorted. I am going to be running an in board ally tank as well. Just need to double check on what filters and type of line to use now. Quote
