I've rebuilt my engine only thing I haven't changed is the oil pressure switch I bought one from I'd workz but it doesn't seem to fit :/ is it imperative that I change it guys?
I got my oil pressure switch from id workz it's tight on but it doesn't go all the way in on the thread so if that's what you have then someone needs to quote us if this is right or not as my engines in a middle of a rebuild aswell 👍
  • 2 weeks later...
Back to this subject just out of curiousity is the oil pressure switch suppose to go right in screwed tight so the switch itself is tight up against the block? As mine doesn't do that it's on tight but there's still a gap there 👍
