Djaniero Posted October 14, 2014 Posted October 14, 2014 Got the common dreaded boot on leak on my ep82....I'm 99% sure its coming from the rear lights. I've done a search, and a few peeps said to reseal behind the lights....but has anyone got any pics of where exactly it is I need to reseal with silicon? Thanks Quote
Jamie_VF22 Posted October 14, 2014 Posted October 14, 2014 I had this problem with my EP82 i just pulled both lights out and just sealed the whole way around the light and it never leaked again No pictures im afraid though mate Quote
Djaniero Posted October 14, 2014 Author Posted October 14, 2014 Thanks man!Did you seal around the actual light clusters, or put the sealant onto the bodywork? Quote
Jamie_VF22 Posted October 14, 2014 Posted October 14, 2014 Around the light clusters mate then bolt it up and leave it Quote
Djaniero Posted October 14, 2014 Author Posted October 14, 2014 Cheers for that Jamie...I'll get on the case this weekend Quote
aaddzz123 Posted October 14, 2014 Posted October 14, 2014 There are only 3 small holes behind the lights, sealing the whole light might be a little over kill lol. It's more than likely the little rubber mount that the light slots into. I've had to change mine a few times. Be best to pop the light out and just squirt some sealant inside the rubber and around the outside of the rubber. Quote
Jamie_VF22 Posted October 14, 2014 Posted October 14, 2014 There are only 3 small holes behind the lights, sealing the whole light might be a little over kill lol. It's more than likely the little rubber mount that the light slots into. I've had to change mine a few times. Be best to pop the light out and just squirt some sealant inside the rubber and around the outside of the rubber. Would rather over kill then it leak dude Quote
aaddzz123 Posted October 14, 2014 Posted October 14, 2014 Would rather over kill then it leak dudeLol. Not slating what you've suggested mate. Just using half a tube of sealant for what is probably a 1mm hole is a bit much? Plus you'll have to reseal them every time you have to change a bulb and itd be stuck in there good with all that sealant on there. Quote
