Mcinnes Posted October 15, 2014 Posted October 15, 2014 i've just got a new engine and turbo still standered and my turbo is not kicking in at all and is making a constant whistle when i put my foot down does anyone know what the problem could be ? Quote
mikey4410 Posted October 15, 2014 Posted October 15, 2014 Thats a classic boost leak noise matey.you need to check all ure pipes Quote
Mcinnes Posted October 15, 2014 Author Posted October 15, 2014 Does anyone know a common place where there's a turbo leak as i can't find it Quote
Ollieh17 Posted October 15, 2014 Posted October 15, 2014 Remove the air filter and block up the turbo inlet. It will then make the boost leak obvious. If there isnt a leak the car should cut out Quote
Ryan_EP82 GT Posted October 17, 2014 Posted October 17, 2014 Check wwhere manifold and decat join to turbo Quote
