Hello guys and greetings from Cyprus!!!
We finished tuning last night and made 279 whp and 313nm of torque!!!
The car is on 98octane pump fuel and the engine is a forged 4e with 5e cams and fully stock head!!!
Turbo is Vf30 and we boost it at around 1.8 bar but it cant hold boost and it drops it about 1.55 to revlimit!!
How can i hold the boost up top to 1.8 so we get close enough to 300whp range????
Also the Ecu is a standalone Adaptronic 440d !!!!
What wastegate spring are you using? If running a soft 0.8 bar or so you will need to change to a stiffer one something like 1.4 bar.
We dont have boost controller!!! We have the n75 boost solenoid from an Audi and everything is controlled by the ECU!!! The wastegate is a Turbonetics Evolution and i think the spring is 0.8 or 0.9 but its very stiff !!! you cant push it with your hand !!!
Change the spring to a 1.2 or 1.4 bar spring. Makes no difference whether you can push it or not, the force the air will exert on it will be more than you could ever provide.
