Beany GT Posted October 20, 2014 Posted October 20, 2014 Hi everyone, my clutch has blown up so I've just started dismantling her to take the gearbox out, an seen as I've got a few parts waiting to be fitted going to do them too.Question 1 - should I have oil in my front mount intercooler pipe work? If not is that a rebuild? Question 2 - is there other option for ct9 water pipes? Or shall I just replace the pershied rubber hoses? Question 3 - how much would a ct9 rebuild be? An how much extra would it be to go hybrid an make it EWG? Question 4 - what is the black cyclinder next to the fuel filter? An can it be deleted? I think that's all for now, untill I uncover more problems :) Thanks in advance !!! At this rate I might as well start a build thread ha Beany!! Quote
Beany GT Posted October 20, 2014 Author Posted October 20, 2014 If I'm right in thinking question 4 is a carbon canister? Can I rem If I'm right in thinking question 4 is a carbon canister? Can I remove it like I did on my old eunos? Quote
JamesD89 Posted October 21, 2014 Posted October 21, 2014 Question 1 Is your turbo running as normal? Question 2 Yeah just replace them with rubber or silicone items they are available. Question 3 Pm Liam D on here a standard rebuild is £199.99 iirc depending what's wrong with it. Question 4 Yes its a charcoal canister and people have removed them, there is a quite recent thread on here if you do a search. James Quote
JamesD89 Posted October 21, 2014 Posted October 21, 2014 http://www.ukstarletowners.com/topic/40085-removing-sensors-charcoal-canister-etc/?hl=%2Bremoving+%2Bcharcoal+%2Bcanister Quote
Beany GT Posted October 21, 2014 Author Posted October 21, 2014 Thanks for the reply, the turbo was running the same as when I first got the car, before the clutch went, but I don't have anything to compare it with being honest, do you know where to purchase these? ID-works or similar? An thank you, I managed to find a lot of information after searching the interwebs last night Thanks again. Quote
JamesD89 Posted October 21, 2014 Posted October 21, 2014 Roose motorsport, samco, ash etc stock them mate. Quote
