fiddlersport Posted October 20, 2014 Posted October 20, 2014 removed a oem lsd box from a glanza and it had the original non lsd sandwich plate had to remove the extra cup which is on the lsd box -(shorter shaft side cup) noticed the oem lsd sandwich plate is in two pieces any particular reason its in two pieces ? which seals should i replce while the box is out and recommend me a decent oil pls thanks Quote
5e colin Posted October 21, 2014 Posted October 21, 2014 because a single peace fouls it it wont fit unless trimmed bent replace both driveshaft seals and the seal between box and viscouse Quote
