Hey everyone, when looking under my ep82 should I be able to see the flywheel, as in it's exs posed?!?
Is there a cover missing?!
Can I get another?
Has someone got another?!
Seems Abit dodgy just having it exposed, don't want nothing flying into there tbh...
Thanks Beany!
Not entirely sure, I'll hopefully get the box off tonight. But if you look at it from the drivers side, you can see about a 1/4 of it, it looks like there should be a cover ?
Yeah should defo not be exposed as it will let water, road dust and shit etc in there.
as above the sandwich plate is missing I guess, thats just somebody been to lazy to refit when reoving gearbox.
Unfortuantley you can only fit it up when gearbox is off :-(
Well I've got too remove the box anyway, but that also means I'll need the flywheel off? As I can't see a cover going around it to fit?!
If its the backing plate originally that came from an auto then it will have an opening so the torque converter can be unbolted when removing the box
It's a manual, an I can't see no plate, I ran out of light last night to get it off, but is there any photos of gearboxes etc installed?
As googled it but no luck
