PaddyDoyle Posted October 23, 2014 Posted October 23, 2014 Doing the timing for the first time on a 1E engine.Have the camshaft gear set spot on with "1E" mark at 12 o'clock. I spin crank to get it to TDC and am coming against a valve. Should I set crank at TDC first then spin cam to timing mark?Thanks Quote
5e colin Posted October 24, 2014 Posted October 24, 2014 take the belt back of then set the bottom end timing when you hit a valve move the cam a bit to set the timing simple job Quote
