Can any one help I've just had this new engine put in still 1.3 turbo and it's not starting properly it only happens when it's been left over night. It take about about 5 to 10 mins to get it started and when it does come to life it kicks at white smoke for a little while out of the exhaust. Just changed all the spark plugs anyone one know what the problem can be?? And also when it starts the noise is quite deep from what I remember of it
Sounds like battery or starter motor mate.
The white smoke will be condisation if it just smokes when cold dont worry its something to worry if your still pumping white smoke when your cars upto temp.
What is ure battery voltage at dude ?
When was coolant temp sensor last replaced/renewed ?
how does it start once warm ?
Edited by mikey4410
Voltage is at 12.3 and had always been on that sense I got it and only time I've had a problem is when new engine went in.
And sarts fine when warm but the engine doesn't sound how it should and haven't changed it in a while
