With no fpr?
Wait didn't you hit fuel cut running 0.8?
td04 and td05 were with the standard fpr, gt28 i had and adjustable fpr set to standard fuel pressure.
nope no fuel cut!
Ahh I see! I have a sard fpr ATM but will be unwired till I get it mapped, really I though anymore than .6 would hit fuel cut!?
But fuel cut is 0.85 though?
Okay this is annoying now I keep gettiny told different things... Some say I'm gonna hit fuel cut running anymore than 0.6? Do you think it will run safe at 0.8 with only a front mount on a standard ecu? No fpr or fuel cut defender
Fuel cut is determined by Map sensor reading iirc so is an exact voltage rather than psi or bar cant mind what it is though.
boost creep is your biggest enemy when trying to avoid fuel cut on a modded 4efte.
0.8 is the ball park i think
Phil
Okay cheers Phil great help :) gonna run it at 0.5 bar just to be safe and hope it fuels safely till I get it mapped
Good choice I'm running a 0.5 nice and safe till mapping comes all you need for now :)
Haha yeah at least I hope it's safe, out of curiosity are you using a fuel cut defender or fpr?
No I'm not I would say never run a fcd fc is there for a reason to protect the engine just wait till you go for a map and dyno and fit your fpr then that's what I'm doing
