white-gt Posted October 26, 2014 Posted October 26, 2014 ok guys so ive bought a replacment tall block instead of rebuilding mine. its got 62k miles with compression im told of 170psi across the board. im not keen on using an engine flush really, i usually use 5w-40 shell ultra but would i be best to use a very cheap semi synth oil to flush round the engine for say 10 miles, then flush and put decent 5-30 or 5-40 oil in?or would an engine flush be better ? Quote
mikey4410 Posted October 26, 2014 Posted October 26, 2014 (edited) Dont use engine flush unless u accidently filled you car up with yogurt or milk.but seriously don't use the stuff.use some semi for a lil while making sure you have a magnetic sump plug.(keep the magnetic one even after the fully goes in)Then the oil I would use is 5/40 and has to be fully synthetic. Edited October 26, 2014 by mikey4410 Quote
Matt1878 Posted October 26, 2014 Posted October 26, 2014 Yeah as above .. Flush is awful.. I've just serviced mine with a 5w-30 fully synthetic and runs lovely Quote
white-gt Posted October 26, 2014 Author Posted October 26, 2014 ok lovely, seems to be either 5-30 or 5-40 to 10-40 is the way to go, .. ok thanks guys Quote
