llawgoch Posted January 3, 2006 Share Posted January 3, 2006 is there any thing important i need to take into account when im putting the 5e-fe into my SR.I have the ecu by the way. What exhaust maifold do i use Paseo or Starlet. it should be a little quicker then shouldn it. Quote Link to post Share on other sites
scutch0 Posted January 3, 2006 Share Posted January 3, 2006 it should be easy peasy... altho, dont take anything for granted with engine conversions.... i learned the hard way.this thread can only really be answered by whitestarlet...all the best.Rich. Quote Link to post Share on other sites
whitestarlet Posted January 3, 2006 Share Posted January 3, 2006 the manifold i used came on the 5e-fe engine so i had no problems getting it up and running one of my temperature sensors was different but it was only a mater of changing over the sensor in the thermostat housing. one problem i had was the fan stayed on constantly but if you get a fan sensor with 2 terminals on it earth on to the engine and put the other into the sensor wire!! an outo spark should be able to sort that out no problem!! ! yeah it should mate and put on the JDM intake manifold aswell Quote Link to post Share on other sites
whitestarlet Posted January 3, 2006 Share Posted January 3, 2006 duty done!! lol if you have anymore probs post them up but i dont think you should!! are you using the starlet wiring loom??? cause thats wat i did!! oh dear now im gonna hadda get the finger out so i dont have the lowest powered N/A 5e starlet!! Quote Link to post Share on other sites
wylo Posted January 3, 2006 Share Posted January 3, 2006 Whats the wiring like mate? Did you get someone do do it?Is the difference well noticeable yeah? Quote Link to post Share on other sites
whitestarlet Posted January 3, 2006 Share Posted January 3, 2006 the starlet wiring loom is fine! its was just thatt plug that was different! plus the one on the throttle body i forgot about though i kept the 4e one on!last RR was 103.something bhp at fly and 117 i think NM torque so yeah it is noticable Quote Link to post Share on other sites
scutch0 Posted January 3, 2006 Share Posted January 3, 2006 hmmmmm i wish i could have got my 5efhe running ;) i would have loved to see the output and 0-60 time.Rich. Quote Link to post Share on other sites
wylo Posted January 3, 2006 Share Posted January 3, 2006 whitestarlet said: the starlet wiring loom is fine! its was just thatt plug that was different! plus the one on the throttle body i forgot about though i kept the 4e one on!last RR was 103.something bhp at fly and 117 i think NM torque so yeah it is noticable<{POST_SNAPBACK}>cool. cheers for info Quote Link to post Share on other sites
llawgoch Posted January 3, 2006 Author Share Posted January 3, 2006 whitestarlet said: the manifold i used came on the 5e-fe engine so i had no problems getting it up and running one of my temperature sensors was different but it was only a mater of changing over the sensor in the thermostat housing. one problem i had was the fan stayed on constantly but if you get a fan sensor with 2 terminals on it earth on to the engine and put the other into the sensor wire!! an outo spark should be able to sort that out no problem!! ! yeah it should mate and put on the JDM intake manifold aswell<{POST_SNAPBACK}>what do you mean with the fan? was it a fault with yours or will i get the same problem as well? cant i just swap the temp switch or something? does the fan work through the ecu which, combined with a different temp sensor, would think it was running hotter than it was. (did you understand that last bit?) cheers Quote Link to post Share on other sites
whitestarlet Posted January 3, 2006 Share Posted January 3, 2006 the radiator fan mate!! should have made that clearer. i tried different sensors lower and higher temp but nothing worked.the fan just kept running! i dont know what causes it. i was talking to jaystarr at the time and he said when the air-con was removed from a GT the fan stayed on but since i didnt have the Paseo wiring loom i couldnt bridge the 2 wires like i should have been able to do. it hasnt been running hotter at all because the fan was on constant but on the guage on the inside of the car (dash) the temerature needle stayed in the middle!hope that helps Quote Link to post Share on other sites
