Manix90 Posted October 29, 2014 Share Posted October 29, 2014 Hey guys, now winter is starting to set im struggling to keep my windscreen clear partly because the fan in the heater keep giving up or sticking and the dash needs a few slaps of encouragement to get it going and when it is going it puffs no harder than an athematic squirrel that's had a lung removed. Anyone one got any ideas on supercharging the system maybe with a new motor or just a clean out? How my h work is required to get to the fan motor?SteamilyMatt Quote Link to post Share on other sites
morgey Posted October 29, 2014 Share Posted October 29, 2014 Depending on car you may have a pollen filter than can be cleaned or replaced. That can be got at from under the glovebox. If you have you you'll see 3 little black mushroom shaped bits facing towards the back of the car. Pull them out then a panel pulls down and the 2 filters slide out. But if you dont have that im not sure of your options, the fan is to the left of that tucked up behind your glove box thats probably where id start. Quote Link to post Share on other sites
