sophiealice Posted November 13, 2014 Posted November 13, 2014 Any help? Glanza has got a misfire when cold it's perfectly fine but soon as it gets up to its temp it starts to misfire and hardley moves and the revs just don't stay up or anythin they constantly drop . It only happened since even sat in traffic for 3 hours constant stop and start we quickly checked everything and what we could see was that it was missing from the 4ht lead so we got a new one from Toyota and we fitted and it ran mint and then when took it for a drive it started missin again we checked the dizzy cap and it was full of shit like it's never been of since been on the car so we cleaned it up but tbh I think could do with a new one any chance that the coil could be getting to warm? Quote
Pinkygti Posted November 13, 2014 Posted November 13, 2014 Been following you in Instagram coil packs are know for messing around due to heat issues. The fact that it does it when under load (ie revving it) also points to the coil, am sure someone on here has an old one you can chuck it on to check it Quote
fiddlersport Posted November 13, 2014 Posted November 13, 2014 bad earth on the coil, check it out, its common Quote
sophiealice Posted November 14, 2014 Author Posted November 14, 2014 Thanks for the help guys I have put new coil on tonight and it hasn't worked what' shall I try next ? Changing he spark plugs ? Dizzy cap ? Rota arm? Quote
Pinkygti Posted November 14, 2014 Posted November 14, 2014 Have you any fault codes in the system? Management light on? Quote
sophiealice Posted November 14, 2014 Author Posted November 14, 2014 No lights have come on for the engine or anything accept other day I was going up a hill in tragic on way to work and it was a nigtmare the revs would stay up the name to a stage were there car actually would move at all and the light that comes on for when the cat gets to warm came up Quote
sophiealice Posted November 15, 2014 Author Posted November 15, 2014 (edited) Spark plugs have been changed Edited November 19, 2014 by sophiealice Quote
sophiealice Posted November 19, 2014 Author Posted November 19, 2014 Does anyone have any other ideas what could be up with my car everything I thought if has been changed accept dizzy and rota arm Quote
