Fan doesn't seem to cut in . Temperature is steady till I boot it then it rises to 90 % pulled over to find a slight leak from a hose not clipped properly. Fixed that drove off. Booted it and it rose again and no fan... rads a half civic rad with small fan to suit. .. any ideas
I checked the water level and it dropped from the cap to just above the cooling grids in the rad so a few cm il bleed it aagain and see but still need the fan too work -_-
Right replaced the fan switch as found that wasn't working. Ran car up fan didn't cut in temp got to the thick grey bar below H on gauge so I turned her off... waited 10 seconds restarted and the fan was on for 10 seconds then went off ?? Dodgy thermostat maybe
