srferreras Posted November 30, 2014 Posted November 30, 2014 Hello mates, anyone know how to connect the boost selenoid in PowerFC? Quote
Mk3 silver gt Posted November 30, 2014 Posted November 30, 2014 You should have a yellow connector port on the side of the unit and you plug the solenoid harness in there and and access it through the hand commander Quote
srferreras Posted November 30, 2014 Author Posted November 30, 2014 (edited) the solenoid does not connect where is the factory solenoid that controls the high and low boost? Edited November 30, 2014 by srferreras Quote
karl. Posted November 30, 2014 Posted November 30, 2014 Yes it does, then you need to plug your map sensor into the side port of the power fc. Just join the solenoid with a bit of solder or something to the standard wires, I don't think it matters which way Quote
srferreras Posted November 30, 2014 Author Posted November 30, 2014 I'm well confused. there is a diagram? Quote
karl. Posted November 30, 2014 Posted November 30, 2014 How many pins are in the hole for the plug in the ecu? If 3 then you need to connect the map sensor to that then connect the solenoid to the standard wires. If there is 5 pins then both the map sensor and the solenoid connects to the ecu. Quote
srferreras Posted December 7, 2014 Author Posted December 7, 2014 that difficult. someone help me how to install it using the map sensor factory Quote
