Crack in exhaust housing is totally fine aslong as its not running where the turbine wheel runs or leaks gases externally. You don't need a new turbo.
I think where it is tho has stopped my actuator working so the flap for the screamer lip is constantly open :/ can you just change the housing ?
im not too sure think the b's normally come printed on so looks exactly what i need so its running fine you said?
When I got the car the turbo had oil around it so I thought it was faulty, so fitted a new ct9 but it didn't fix the fault, it was the pcv valve sucking oil into the inlet. So I assume the ct12 is ok. I was looking for £100 posted to uk as I was told they are rare and a type of hybrid? Also have a jam ecu for sale if you know anyone who wants one. Let me know what you think.
Edited by Manny01
Ahh so did you manage to fix the fault in the end? Mines got a crack through the housing on the hot side and is blowing exhaust gases out of the hole sounds awful
Yeah im not actually sure what the ct12 is but mine had one fitted when i bought it so im just looking to replace it not sure if there a hybrid tho? Theres so many versions of it !
Hpw about £80 posed ?
Yeah il ask around for you :)
