Was driving my glanza the other night the engine check light come on and stayed on done a fault code check and code 22 came up which is open or short circuit in coolant temp.
Would this stop the car from starting?
Ive herd that some cars will refuse to start if there is no coolant temp signal the car was fine right up in till Saturday night when a was having a blast with a audi ever since the the car struggles to start from cold takes about 8 attempts to start and when it does it idles rough as fuck soon as you give it gas it cuts out but if you start it again and let it heat up it's fine drive & boosts fine and starts fine left it to cool down and it's doing the same thing again
Yes it will be a pig to start and will run like crap if the coolant temp is faulty. If the ecu doesn't see a temp it will revert to a preset generic temperature setting. So when it's cold it needs to run a lot richer to run smooth until it warms up, yours isn't doing that, hence your issue bud.
Best bet is to change the sensor, mine went and would refuse to start a second time, first drive of the day was fine any thing after was a nightmare to get her started
TD sell them for £35ish :) just check what pin type you have :) 2 or 3 ?
James
Was having the same problem with our Demo GT, didn't have a clue what was wrong with it. Did it get worse as in take longer to start or was it the same?
Aamir
Aamir
the car was fine mate until Saturday night was giving it big stick then the engine management light come on and wouldn't go off the next day a went to take the car out it wouldn't start management light was on still on it taken me about 8 attempts to get it going a replaced the engine coolant temp sensor and now it's fine starts first time
Aamir
Mine got worse as the sensor got worse !
