On my starlet glanza the decals on the back and sides under the windows are peeling away an i want to remove them and replace them with some fresh new ones but where can i get them? also when i remove the old ones is it likely the outline of the decal will still be there in the paint due to slight fading over the years ?? cheers guys starlybruiser :D
Ebay mate, you can get replacement stickers on there. As for the dark tide marks left behind from the old stickers, get yourself a machine polisher and some compound, and run the polisher over the affected area, making sure you go slow enough to heat up the panel. This will take off a very fine surface of the paint, eventually making it all the same colour and considerably shinier.
Hope this helps,
Alex.
Hope this helps,
Alex.
ok mate will try that, thanks for the help cheers starlybruiser :D
