Boylo99 Posted December 3, 2014 Posted December 3, 2014 1992 ep82as above when driving scraping metal noise as you go faster it gets faster if you slow down it get slower becomes more noisy slower tho :/firstly thought wheel bearing but there doesnt seem to be any movement in the wheel itself ! i did read that pads dragging on the disc is common or possibly even the guard on the disc may be rubbing any one had the same problem?!? Quote
toyotag2014 Posted December 3, 2014 Posted December 3, 2014 you might have got some metel stuck inbetween the pad and disk mate take the pads out and check fella Quote
Boylo99 Posted December 3, 2014 Author Posted December 3, 2014 Yeah gona have a look tomorow but im not to sure it brakes as the noise is still there when you apply the brakes :/ still thinking it could be a wheel bearing but i thought that was more of a rumble ? Quote
toyotag2014 Posted December 3, 2014 Posted December 3, 2014 yh it is more of a rumble if i was you jack the car up spin the wheel and see what noise you can hear mate but i reckon you might have crap or something in the pad way Quote
Boylo99 Posted December 3, 2014 Author Posted December 3, 2014 Yeah theres no noise when u spin it by hand seems to be when its under load could it be a warped disc possibly ? Quote
toyotag2014 Posted December 3, 2014 Posted December 3, 2014 jack both sides up put axle stand up start the car up accelerate and listen out that will be you best option if you cant hear it by hand Quote
Boylo99 Posted December 3, 2014 Author Posted December 3, 2014 Yeah il have to try this tomorrow will post how it goes cheers for the reply Quote
toyotag2014 Posted December 3, 2014 Posted December 3, 2014 no probs fella if you have trouble but you hear a noise take a vid with goodish sound and post it up Quote
Rosso321 Posted December 4, 2014 Posted December 4, 2014 Have you check the wheel bearing is there play in the wheel cv joint? Ball joint? As my car is in the garage as we speak from same symptoms. Quote
Boylo99 Posted December 4, 2014 Author Posted December 4, 2014 ahh really yeah mines going in todayno play in the wheel or joint no ! let me know what they find ! Quote
Boylo99 Posted December 4, 2014 Author Posted December 4, 2014 there saying could be driveshaft? Quote
Boylo99 Posted December 4, 2014 Author Posted December 4, 2014 turns out it the flange on the driveshaft bearing has worn it away ! :/ :sad: :sad: Quote
Nashy_sba Posted July 22, 2015 Posted July 22, 2015 Did you find ever find out 100% what this noise was , I have the same one haha brakes have all been off and cleaned and put back and its still there ??? Quote
