ugglasdav Posted January 4, 2015 Posted January 4, 2015 Hi guys having an issue with the clutch in my car i think, firstly only have to lift the clutch pedal barely off the floor and the clutch engages, very small movement needed, then also i cant select 1st gear sometimes aswell as getting out of 1st when stopped, thinking there is something leaking and the clutch isnt full disengaging Quote
drongo boi Posted January 4, 2015 Posted January 4, 2015 I had a similar problem on mine i just adjusted the clutch pedal ans its bin mint since Quote
aidanep71 Posted January 4, 2015 Posted January 4, 2015 Check the slave cylinder on the box for leaks sounds like there's air in the system Quote
