I get a bit confused tho do all 4efte cranks use the same size bearings or are there different sizes for different years
Just phoned toyota there saying there are 3 different types mk1 mk2 mk3 and i need the numbers stamped on block and con rod how come they say that but acl and all aftermarket companys just do one size . Very confusing lol
I agree that its weird acl only do one size but toyota do 3! I emailed idrees a while back to see if he could tell me the sizes for standard acl but didnt hear anything.
Heres the limits from toyota for each size of bearing
Big-end inner diameter:
STD mark 1 = 43.000-43.007mm
STD mark 2 = 43.007-43.014mm
STD mark 3 = 43.014-43.021mm
Main journal diameter:
STD mark 0 = 46.995-47.000mm
STD mark 1 = 46.990-46.995mm
STD mark 2 = 46.985-46.990mm
http://www.toyotagtturbo.com/forums/showthread.php?27568-4EFTE-Torque-Specs
thats simple because they use the mid size bearings ( thats what al non toyota bearings are sized on ) so some will be a tat tight and a tat loose but still in tolerance
you use plasti gauge when fitting these and check tollerances that way :) :)
