right the glanza is burning oil so the first thing I tried was different turbo (td04l) no joy, then I removed manifold and seen oil on valves so changed oil stem seals and head gasket while head was off and still no joy.
is there a way I can do away with the pcv valve to see if that's making car burn oil?
if that doesn't work does that mean the oil rings are gone?
kevin
