sosolid Posted January 8, 2015 Posted January 8, 2015 I recently relocated my filter to the front and drove it today when it was raining and obviously it was wet. Would this harm or do anything to turbo, engine or performance? Quote
Pinkygti Posted January 8, 2015 Posted January 8, 2015 Be advised that any water (ie flood water) that will get past the filter will make your engine go popYou can't compress waterGeneral rain water might be ok tho, wouldn't risk it myself and run a standard air of during winter Quote
Ollieh17 Posted January 8, 2015 Posted January 8, 2015 Unless you cover the filter in water it should be fine mate. Minimual water will get through i woulda thought. Quote
Calum122 Posted January 8, 2015 Posted January 8, 2015 True lol. I wouldn't worry about it too much. On my bike I modified the intake to a bigger carb. But this meant I could no longer use the standard airbox so have opted for a RAM filter which is basically a sponge right next to the shock. I ride in all weathers and have never had a problem. I've also been known to jet wash the fck out of the bike, launch a bucket of water at the engine and carb and then fire it up and ride off. I'm sure if can survive that then it'll survive a little rain water. Quote
sosolid Posted January 8, 2015 Author Posted January 8, 2015 Thanks for the input guys the air filter aint soaking wet but im putting a heat shield around it to stop water getting onto it. Also most starlet owners who modfy there cars relocate to the front, just behind the intercooler so has anyones car eninge gone 'pop' from a wet air filter. Quote
