td hybrid td04 air filter, water nd oil lines wanted
As above lads was not sure if the hybrid had a bigger housing then normal td04.also need oil return that bolts to bottom of turbo and rubber pipe to the sump.
Mickey4410 put a list of what you need to make some water lines in his build thread. Would
Imagine its the same core for a hybrid
