Phil Posted January 11, 2015 Posted January 11, 2015 I've got some custom piper cams budTell Chris green about these he will be interested Phil
Phil Posted January 11, 2015 Posted January 11, 2015 lol an so am i, hence this postLol true true.I can get you billet cams from sam@speedvision if you wanted? I usually get good discount, been a customer/tester down the years.Phil
tango123 Posted January 11, 2015 Author Posted January 11, 2015 just wondering if thats the best way to go or stock cams an cruise valves to allow more revs?? bit unsure :/
Phil Posted January 11, 2015 Posted January 11, 2015 just wondering if thats the best way to go or stock cams an cruise valves to allow more revs?? bit unsure :/What turbo you running?What revs are needed?I'd consider either leaving the head stock or going all out so it's done right once.To do it right on a budget I'd go Piper regrinds4age valves 0.5mm oversize4age springs 1zzfe (yaris) solid shim less bucketsTo go mental without budgetBillet cams Cruise valve springsSupertech retainersSupertech valves 1zzfe bucketsPhil
tango123 Posted January 11, 2015 Author Posted January 11, 2015 i have a billet wheel td04 to go on bud
