These are the bailey dump valve install instructions, but i have no idea what it means?? can anyone tell me what i need to do to fit this?? here they are starting from step 2:
2) after locating the re- circulating dump valve remove the vacuum feed and follow it back to its sourse and remove the standard vacuum hose from the vehicle.
3) very carefully remove the 19mm 90 degree hose from the top of the standard dump valve and twist 90 degrees to the left so as you are looking at the engine the hose is pointing to your left.
4) Next place the bailey 20mm- 32mm staright alloy adapter into this open hose and push on the 25mm diameter samco hose onto the other end.
5) last step is to connect the supplied vacuum hose to the top of the dump valve and the other end to the metal pipe you took it off.
Any idea what the hell i gorra do?? its confusing lol cheers starlybruiser :p
im sorry that i cant help you more but do you have a starlet specific fitting kit for your ep as it really is a simple process to fit?
