Turbo Goose Posted January 12, 2015 Posted January 12, 2015 Hi guys. My forged engine is nearly complete i just need a headgasket!Ive been advised on a paseo 0.5mm headgasketAthena are about £100 where as paseo ones can be had for around £30I have 8.5:1 wiseco pistons and will be running a td04Just wondering if a .5 headgasket would give to high compression, should i opt for a thicker athena 1 eventhough they are 3x the price?Thanks guys,Dan Quote
5e colin Posted January 12, 2015 Posted January 12, 2015 how much boost are you planing to run ???? under 1.2/1.3 then use oem toyo gaskets are pretty strong Quote
Turbo Goose Posted January 12, 2015 Author Posted January 12, 2015 I plan for 270+ bhp so i think id be pushing around 1.4bar (correct me if thats off) Quote
5e colin Posted January 12, 2015 Posted January 12, 2015 go for athena then thickness is your choice me i would go 2 mm just for safety its easier to map Quote
AdamB Posted January 12, 2015 Posted January 12, 2015 Firstly what ecu have you got and who's going to map it? Do they know starlets well? I would choose the 0.5mm, the E series engine lacks peak pressure as it is, lowering the compression ratio isn't going to help much. Quote
Turbo Goose Posted January 12, 2015 Author Posted January 12, 2015 Ive got an emanage blue and get it mapped at racetech Quote
