4e-fte engine.
had knock sensor code come up so change the sensor today, took the car a run once i changed it, got home and tried to start the car again but nothing its just turning over. any help is appreciated. no codes on the dash. Thanks
just an idea but it is earthed correctly on battery and I've seen a glanza not start due to some earth cable attached to inlet manifold that came loose and when re attached it fired up straight away
