Craigtrials95 Posted January 13, 2015 Posted January 13, 2015 4e-fte engine. had knock sensor code come up so change the sensor today, took the car a run once i changed it, got home and tried to start the car again but nothing its just turning over. any help is appreciated. no codes on the dash. Thanks Quote
davies700 Posted January 15, 2015 Posted January 15, 2015 just an idea but it is earthed correctly on battery and I've seen a glanza not start due to some earth cable attached to inlet manifold that came loose and when re attached it fired up straight away Quote
Ollieh17 Posted January 17, 2015 Posted January 17, 2015 Glanzas dont have a crank sensor. The earths still attached to the inlet where the Idle control valve bolts on? Quote
