GavinsBeard Posted January 16, 2015 Posted January 16, 2015 Is it worth sticking a Corolla inlet on my NA? Quote
FrozenJakalope Posted January 16, 2015 Posted January 16, 2015 From what I've read, it ups the power noticeably. More power lower in the range and a bit of a boost to HP. Quote
Pete_A Posted January 16, 2015 Posted January 16, 2015 I to would like to know more. Which years? Which engine size? And alao can glanza intakes be used?And do you need the inlet complete with all the other bits?Sorry to thread hijak. Quote
FrozenJakalope Posted January 16, 2015 Posted January 16, 2015 I to would like to know more. Which years? Which engine size? And alao can glanza intakes be used?And do you need the inlet complete with all the other bits?Sorry to thread hijak.1) Any Rolla with a 4EFE, up to 1999/2000 I believe2) All 4EFEs are 1332cc3) You can, but my understanding is the gains aren't as good as the Rolla tubular type mani4) Pass. I think it's just bolt on but someone who's actually fit one would be able to give a much more complete answer than me Quote
lukebrown4321 Posted January 16, 2015 Posted January 16, 2015 I have recently fitted the corolla inlet manifold and yes i would say its a must do mod for the n/a nice increase in low down torque not huge but its noticeable Quote
lukebrown4321 Posted January 16, 2015 Posted January 16, 2015 (edited) Just need the manifold everything else matches up. corolla manifold is just a straight swap bolts out swap over and bolts in. Taking the fuel rail off will also make it abit easier to do but not necessary Edited January 16, 2015 by lukebrown4321 Quote
lukebrown4321 Posted January 16, 2015 Posted January 16, 2015 Dont forget a intake manifold gasket while your on there Quote
onnaj1000 Posted January 16, 2015 Posted January 16, 2015 Don't forget to buy at least 1 stay for it! And you have to put the earth cable somewhere else and be a little bit inventive with the throttle cable. Quote
