*sean_glanza_v* Posted January 17, 2015 Posted January 17, 2015 About to fit levin twinpot brakes. Think I will be needing extended wheel studs due running rota grid drifts as well any ideas if this is possible Quote
nikhilkamdar12 Posted January 21, 2015 Posted January 21, 2015 You mean spacers? Also probs depends on your offset but I seen people run 4 pots under them so a Levin setup should be cool without spacers Quote
RichWillmore Posted January 21, 2015 Posted January 21, 2015 Hi, I have just fitted some myself, i had to space the wheels more than the 3mm sugguested, in the end 7mm.I have brought some extended studs, look as if they are needed. I paid £16 for a set of 8 and spacers were about a 5'er delivered. Hope this helps Quote
