It's an ITG mate, I can get you the part no. If you need, it's the perfect size for mine and being foam it has a bit of flexibility. I had a blitz too, bloody huge and wouldn't fit anywhere
Jamie thats the manifold i got off you, struggling to make anything fit with the powersteering in the way lol How was it getting a decent airflow to it there? Have seen that it can make a bit of difference when getting mapped if the filter is stuck behind the headlight
You will matey i didnt run power steering so i had no problem fitting a filter
You will be able to do a set up like mine above with the power steering. The original PAS belt needs to be changed from a 4PK920 to a 4PK898. That brings the pump right down on the mounts and gives enough clearance
