Polson2k9 Posted January 18, 2015 Posted January 18, 2015 Hi, my glanza is tramlining alot and getting bad bump steer at high speeds. Alignment is spot on so cant be that, its drives perfect on smooth roads its just when you put your foot down over bumps, uneven road surfaces etc, doesnt feel right. Got 195/50r15 tyres so dont think its them, any ideas what would cause this? Quote
Polson2k9 Posted January 19, 2015 Author Posted January 19, 2015 Cheers, thought it might be those. Quote
Polson2k9 Posted January 20, 2015 Author Posted January 20, 2015 Will it just be the front bushes that are worn? Quote
Idrees Posted January 20, 2015 Posted January 20, 2015 I would start by replacing the lower arm bushes, both the front and rear bushes in the lower arms Quote
daniel_g Posted January 20, 2015 Posted January 20, 2015 Wouldnt hurt to fire a set of ball joints and track rods in aswell. If they are worn it gives the steering a distant floaty feel. Quote
Polson2k9 Posted January 21, 2015 Author Posted January 21, 2015 So get the 2 front arm front bushes and which one of the rear? The rear beam mounting bush, the panhard rod to beam bush or the panhard rod to body bush? Quote
daniel_g Posted January 21, 2015 Posted January 21, 2015 If it was me id replace the lower arms, they come with new bushes in them and its less fuckin about tbh. And a set of bottom ball joints and track rod ends. Then set alignment up.As for the back of the car theres a few bushes you can get which youve mentioned but they shouldnt affect the steering of the car unless they are totally fucked.Or get a full poly bush set and your sorted lol. Quote
Polson2k9 Posted January 21, 2015 Author Posted January 21, 2015 Should a full poly bush set for the front sort it out do you think? Quote
Polson2k9 Posted January 21, 2015 Author Posted January 21, 2015 What kind of bushes do the lower arms come with? Is it the front arm bushes and the front wishbones aswell? Sorry if im sounding like an idiot not very clued up on cars lol Quote
daniel_g Posted January 21, 2015 Posted January 21, 2015 If its only worn bushes and you replace them with polys then yeah should sort it, but as i said could be ball joints etc worn aswell.Really needs inspected to see whats worn.And alignments gonna need done after doing any jobs like lower arms etc. Thats why its best to do the lot at once imo. Quote
Polson2k9 Posted January 21, 2015 Author Posted January 21, 2015 Yeh ill get my mate to inspect it this weekend, cheers Quote
Polson2k9 Posted January 25, 2015 Author Posted January 25, 2015 Nothing is worn in the control arm. Only thing i think it could be is the rear beam mount bushes, one of them is creaking like mad. Quote
