Hi, my glanza is tramlining alot and getting bad bump steer at high speeds. Alignment is spot on so cant be that, its drives perfect on smooth roads its just when you put your foot down over bumps, uneven road surfaces etc, doesnt feel right. Got 195/50r15 tyres so dont think its them, any ideas what would cause this?
If it was me id replace the lower arms, they come with new bushes in them and its less fuckin about tbh. And a set of bottom ball joints and track rod ends. Then set alignment up.
As for the back of the car theres a few bushes you can get which youve mentioned but they shouldnt affect the steering of the car unless they are totally fucked.
Or get a full poly bush set and your sorted lol.
If its only worn bushes and you replace them with polys then yeah should sort it, but as i said could be ball joints etc worn aswell.
Really needs inspected to see whats worn.
And alignments gonna need done after doing any jobs like lower arms etc. Thats why its best to do the lot at once imo.
