Got these wires left over with no plugs on. Pretty sure the cream wire with brown sleeving is lambda sensor. Guessing one of the others is related to cat sensor?
51C8BE22-192B-46B1-9770-4DE87A63899F_zps
6B95FF51-A3A0-42AB-93DA-081CA2E50975_zps
All the important plugs are plugged in. These must never have had plugs on them since ive had the car. They also leave the loom seperately and one is shielded
Couple of spare earths and likely the oxygen sensor is the other. Check for continuity back to the OX pin on the ecu
