Keri-WMS Posted February 11, 2015 Posted February 11, 2015 We've started doing more of these as people have asked for them, so I thought I better put up a thread! We can make them for other cars too, just ask. Advantages over the cheap rubbish you see: - Cut from 6082 T6 aluminium plate so far higher accuracy and strength than the (cast, and from what...?!!) common ones.- 4x100 holes (only) to maximise wheel contact area.- 55mm clearance hole, so a nice fit on the hub to keep the spacer concentric and eliminate vibration.- Any thickness you like. Thicker ones will of course mean you'll need to find longer wheel studs/bolts etc. Prices are:2mm = £19.20+vat/pr3mm = £22.50+vat/pr4mm = £25.82+vat/pr5mm = £27.50+vat/pr8mm = £34.70+vat/pr(other thickness prices on application) Quote
jayc-glanza17 Posted February 17, 2015 Posted February 17, 2015 Good price keri.I run 10mm spacers with my brake kit which meant I needed m12 wheel studs.Just in case anyone needs to know what they need.. Quote
RichWillmore Posted February 18, 2015 Posted February 18, 2015 Can i have a price for 2 x 8mm Spacers for my Glanza please. Inbox me details. Thanks Quote
