Hi!
I bought this Glanza S in June 2014 and....
1) It had the a turbo intake manifold and air box on it for some bizarre reason which was causing it to run and idle lumpy.
2) The fuel pipe line was corroded
3) The gearbox and shifter was a goner
4) The passenger shaft was a goner
5)The wheel bearings were naffed
6) The throttle was naffed
7) The thermostat housing and water pipe were naffed
8) The distributor timing was retarded
9) Alternator and battery
A BIG THANKS TO ID-WORKZ FOR HIS HELP.
After a frustrating a few months it's finally done.
Here are some pics..
I have just had these wheels power coated to go on...
Edited by spoon
The wheels on the car are 5zigen pro racer gn+ very rare and in mint condition and the ones I'll be putting on are the 5zigen fireball wheels only till the summer then I'll swap them back over.
