Ollieh17 Posted February 17, 2015 Posted February 17, 2015 What have people used to connect the extra cable to relocate the battery in the boot to the original wiring? Quote
_shaun_ Posted February 17, 2015 Posted February 17, 2015 The first time I used a maxi fuse holder and stripped the oem battery terminal off which leaves you with just a square connector. I've just rewired Mine and now the fuse is on the battery side and that same square connector is on a battery kill switch Quote
Ollieh17 Posted February 17, 2015 Author Posted February 17, 2015 Ive seen people use a circuit breaker in the engine bay which can then be kinda used as a killswitch. My plan was like yours to have fuse/breaker on the battery side though. So i could effectively join the wires with the OEM connector and a kill switch? Quote
_shaun_ Posted February 17, 2015 Posted February 17, 2015 Aye from memory the battery terminal just unbolts and I trimmed some extra metal off. The whole was like a MM to small so I just filled it slightly and it bolted straight on Quote
