Lewigi Posted February 20, 2015 Posted February 20, 2015 Hey guys, so currently have a turbo back exhaust system, aftermarket manifold and decat on my glanza v, also an after market air filter. I'm looking to get an ecu to boost up the power a bit , I'm thinking a jam or blitz. I'll be having the car tuned once the ecu is installed aswell. Ive heard that the ecus can be plugged into a standard glanza and work perfectly, Is that correct or will I need supporting mods like fmic,fuel pump and hks actuator ? Or can I just run the car as it is with the ecu? Your advice would be much appreciated! Quote
Gainzy Posted February 20, 2015 Posted February 20, 2015 I think you can run the ecu just stock but obviously more boost needs more fuel so fuel pump first you might aswell fit the fp first then the ecu same time as actuator after reading many posts, the blitz ecu seems the best choice! You won't need a fpr with a plug n play but get a dyno session to be safe I would buy the fuel pump first then the fmic short route but it's up to you. Quote
jimmymac101 Posted February 20, 2015 Posted February 20, 2015 I'm sure I'm correct in saying this......You wont be able to TUNE the ecus your looking at so you will need go think about staying standard ecu and getting a piggy back ( emanage ) and get that set up properly to your set up for best/ safest results James Quote
scottieboi94 Posted February 20, 2015 Posted February 20, 2015 The JAM ecus are plug and play and CANNOT be mapped! I would always recommend getting it mapped on an emanage ecu specifically for your car, it isn't worth risking your engine etc just to buy a cheaper ecu! Quote
Gainzy Posted February 20, 2015 Posted February 20, 2015 It's all about the map at the end of the day, the mapper is only as good as the parts he's working with, leave the map and boost level till the end you won't get the most from your parts with a plug n play technology has advanced there are better options out there now if you have the cash the EMU is a great option, it also removes speed cut while the EMB doesn't! Quote
scottieboi94 Posted February 23, 2015 Posted February 23, 2015 I would certainly get a plug and play ecu as a temporary solution to adapt to the mods you put on in the future and then get it mapped properly after you have done all the mods like Gainzy said Quote
Lewigi Posted March 18, 2015 Author Posted March 18, 2015 Thanks for the advice guys, in the next three months ill be installing a fuel pump, actuator and fmic, then ill get the piggy back ecu and tune it Those supporting mods are good aswell cuz they arent too expensive so should be ready for the ecu in no time! Quote
scottieboi94 Posted March 19, 2015 Posted March 19, 2015 Thanks for the advice guys, in the next three months ill be installing a fuel pump, actuator and fmic, then ill get the piggy back ecu and tune it Those supporting mods are good aswell cuz they arent too expensive so should be ready for the ecu in no time! Sound good mate, nice to see your doing it properly! Quote
5e colin Posted March 19, 2015 Posted March 19, 2015 trow the eblue in the bin and go pfc fcon tune urself with switches :) Quote
