ep91 glanza plasma glow probem...
turn on ignition and the rev counter jumps to 200rpm then jumps back to normal resting position,,,on the stock clocks there is a small plastic pin for it to sit on and after placing the plasma glow dials there is no pin
has anyone experienced anything similar ?
cheers
I have removed the plasma glow dials and when switching on ignition the rpm needle is normal
installed plasma glow dials and the rpm needle jumps to 200rpm ish and then settles back to original position
