fiddlersport Posted February 20, 2015 Share Posted February 20, 2015 ep91 glanza plasma glow probem... turn on ignition and the rev counter jumps to 200rpm then jumps back to normal resting position,,,on the stock clocks there is a small plastic pin for it to sit on and after placing the plasma glow dials there is no pin has anyone experienced anything similar ? cheers Quote Link to post Share on other sites
bucketep91 Posted February 20, 2015 Share Posted February 20, 2015 U must have snapped the pin off when fitting them, as for it jumping up, that'll be nothing to do with the plasma faces. Quote Link to post Share on other sites
fiddlersport Posted February 20, 2015 Author Share Posted February 20, 2015 I have removed the plasma glow dials and when switching on ignition the rpm needle is normal installed plasma glow dials and the rpm needle jumps to 200rpm ish and then settles back to original position Quote Link to post Share on other sites
