Smoke on idle and boost lights
Just a quick few little bits, once the cars been driven and got up to temperature, if I stop after about 5 mins the exhaust starts to smoke a little bit, anyone have this?
And also after fitting new boost guage I noticed that the boost lights on my glanza don't all light up, I only ever get 2 lights tops, boost guage reads 6psi on full boost but stays steady at that,
Running
FMIC
GREDDY BOV
HKS actuator
Fse fpr
Side exit exhaust w/decat
Walbro 255 fuel pump
Normal ct9
Standard ecu with FCD
Any ideas on these issues anyone?
Doesn't sound bad, 0.85 is fuel cut but you have a fcd installed so you can boost more, with proper ecu management you can risk engine damage at the minute your safe but pointless having a fcd. This might help you in the future.
Hmm so maybe I would be better just trying to find a plug and play stand alone? Was looking at a blitz access one because that seemed to do everything I needed
And thank you that's very useful :)
Edited by tommyn1991
