kevmcc90 Posted February 24, 2015 Posted February 24, 2015 Whilst working on car this morning noticed these loose parts sort of hanging about the bay. Anyone shed some light on what they are for? Quote
Ollieh17 Posted February 24, 2015 Posted February 24, 2015 Top one looks like oil pressure plug, second one is aircon shit, can cut that out if youndont use it Quote
kevmcc90 Posted February 24, 2015 Author Posted February 24, 2015 Yeah I don't have air-conditioning anymore it just hangs there. Where would the top one be meant to plug onto? Quote
Ollieh17 Posted February 24, 2015 Posted February 24, 2015 Front of the engine on the block right hand side is the oil pressure switch. It should just slide onto the nipple Quote
kevmcc90 Posted February 24, 2015 Author Posted February 24, 2015 I will have a look man cheers Quote
MARC MOSS Posted February 24, 2015 Posted February 24, 2015 Can we assume that you have an oil pressure light on then? Quote
kevmcc90 Posted February 24, 2015 Author Posted February 24, 2015 Nah there's not a light on man? Quote
kevmcc90 Posted February 24, 2015 Author Posted February 24, 2015 Anyone got a pic of the switch I'm looking for? Quote
MARC MOSS Posted February 24, 2015 Posted February 24, 2015 It plugs into the block just under the righthand of the exhaust manifold Quote
kevmcc90 Posted February 24, 2015 Author Posted February 24, 2015 Yeah I can see that part but it doesn't look like it will plug onto that? As it looks like a spade connector should going into it? Quote
kevmcc90 Posted February 24, 2015 Author Posted February 24, 2015 Anyone got a pic of what should be connected to this? Quote
Ollieh17 Posted February 24, 2015 Posted February 24, 2015 It is a spade connector on the end of the wire... Quote
kevmcc90 Posted February 24, 2015 Author Posted February 24, 2015 Yeah mate well like a female one that would take a spade? Quote
Ollieh17 Posted February 24, 2015 Posted February 24, 2015 (edited) The switch is the female side mate the wire slides on to the circle. Have you tried to do it?should be pretty self explantory bud Edited February 24, 2015 by Ollieh17 Quote
kevmcc90 Posted February 24, 2015 Author Posted February 24, 2015 The cable in the picture seems to be too short to reach to block, are you saying there is another wire should come from the block? Quote
kevmcc90 Posted February 24, 2015 Author Posted February 24, 2015 Right I've got it sorted man. Cheers for your help. I now have an oil light on when I turn ignition on which goes out when car is started? Quote
Ollieh17 Posted February 24, 2015 Posted February 24, 2015 Yeh that sounds right mate, should comeOn with all the dash lights to start with then go out Quote
kevmcc90 Posted February 24, 2015 Author Posted February 24, 2015 Yeah that's spot on man. Take it this light will only come on when there's an issue then Quote
