I would remove the cam cover and pour some oil on the cams and crank over by hand. Put cover back on.
Then remove efi fuse and crank until you have built oil pressure, you will hear the engine noise whilst cranking,(bit quieter) when desired oil pressure is reached.
and also have look at spark plugs for moisture.
Just make sure you have oil pressure by cranking over with EFI Fuse removed and king lead out. Should get oil pressure straight away and then fire her up :)
