Tightening Torques 4E-FE
When I work on a vehicle I always tighten bolts up in 2 stages if there are more then 3 bolts to tighten.
What ever the finishing Nm of torque is half it and do that first so for example if you have a rocker cover that the bolts tighten to 8Nm, tighten them to 4Nm first. After you do them to 4Nm up the torque to 8Nm and repeat the process.
Main bearings Stage 1: 29 Nm
Main bearings Stage 2: 58 Nm
Big end bearings Stage 1: 20 Nm
Big end bearings Stage 2: 40 Nm
Valve Clearance (Inlet) = 0.15-0.25mm cold
Valve Clearance (Exhaust) = 0.31-0.41mm cold
Compression Pressure= 9.8-12.7 bar
Oil Pressure= 2.6-3.6 bar @ 3000rpm
Rad Cap= 0.75-1 bar
Thermostat opens= 80-84 C
Oil pump : 7 Nm
Sump bolts : 8 Nm
Sump drain bolt : 25 Nm
Flywheel/driveplate : 90 Nm/88 Nm
Clutch pressure plate : 19 Nm
Crankshaft pulley/damper centre bolt : 155 Nm
Camshaft sprocket/gear : 51 Nm
Camshaft carrier/cap : 13 Nm
Camshaft/rocker cover : 7 Nm
Inlet manifold to cylinder head : 19 Nm
Exhaust manifold to cylinder head : 48 Nm
Spark plugs : 18 Nm
Lambda sensor (Oxygen) : 44 Nm
Chassis tightening torques
Front hub : 216 Nm
Steering track rod end : 47 Nm
Brake caliper to carrier Front:
-Removable carrier = 25 Nm
-Integral carrier = 18 Nm.
Brake caliper/carrier to hub Front : 88 Nm
ABS sensor Front : 8 Nm
ABS sensor Rear : 8 Nm
Road wheels : 103 Nm (Use zig zag procedure)
Source AutoData
Hopes this is useful to whoever may need information such as this.
Edited by TheAmerican
