alexbennett Posted February 28, 2015 Share Posted February 28, 2015 (edited) As title says XYZ 6pot big brake kit for sale Absolutely awsome set up, recently had new pads which are Mintex racing M144Loads of life left on the discs also and calipers all in fully working order! The below has been taken from the XYZ website: The thickness of the disc is 26mmThe design of bigger vents provides a better function of heat dissipation.The surface of the aluminum centerbell is anodized. It will provide a better durability.The design of a two-piece disc can effectively reduce the weight of the brake system. Aluminum 4 POT caliper (Standard color: Painted red, painted yellow, painted gold, painted black or any other painted colors by customization)High stiffness brake bracket with high ductility boltsStainless steel Teflon brake linesGG level high performance brake pads (Race brake pad is available as well) Disc: The discs from XYZ are the best choice of high performance car models. Ventilated ribs with large diameter can smoothly lead in a great amount of airflow from inside to outside. It will make a better function of heat dissipation. The design of drilled discs can enhance friction factor, reduce the weight of discs, take out the high temperature immediately produced from working, and keep stable braking function. The thickness, 26mm, of the discs can provide a better structural strength. This 286mm brake system is suitable for a 15 inch or a larger wheel Centre bell:The centerbells are made of aluminum. They are equipped with the characteristics of lightweight, good heat dissipation and high structural strength. The surface is processed with anodization. It makes the centerbells harder, increases the durability of weathering, the duration of usage and beautifies the appearances. Caliper: High performance aluminum 4 POT calipers The standard colors are Painted red, painted yellow, painted gold, painted black, any other painted colors You can choose any other painted color to fit your car. The extra fee will be USD100/ pair of caliper. It will take around 15 days for manufactory. For anybody who has ever had a pair of these you'll know they are ridiculously lightweight calipers! AND they can be used under 15" wheels aswell! Only taken some quick pictures, they will be cleaned up before being sent out £700 Located in manchester Can be posted for extra cost Thanks Alex. Edited March 11, 2015 by alexbennett Quote Link to post Share on other sites
alexbennett Posted March 4, 2015 Author Share Posted March 4, 2015 bump Quote Link to post Share on other sites
alexbennett Posted March 11, 2015 Author Share Posted March 11, 2015 Bump up, new price! Quote Link to post Share on other sites
Phil Posted March 11, 2015 Share Posted March 11, 2015 these off and old tmd car that mosley bought a while back? think there is a vid somewhere of these doing the business on track. Phil Quote Link to post Share on other sites
alexbennett Posted March 11, 2015 Author Share Posted March 11, 2015 Yep dude they sure are! Amazing set of brakes, they were £1800 new so real bargain at £700 tbh! Quote Link to post Share on other sites
Phil Posted March 11, 2015 Share Posted March 11, 2015 Yep dude they sure are! Amazing set of brakes, they were £1800 new so real bargain at £700 tbh! 700 is a good price if they are fresh enough no doubt. your full price/new price is way off but no real complaints im sure its a genuine mistake. only know cause i'd love a set and i priced a set with a dealer recently. Phil Quote Link to post Share on other sites
alexbennett Posted March 11, 2015 Author Share Posted March 11, 2015 Almost sure I have the reciept here for them dude haha going to check later on :L Yep in full working order Just had new pads as says about! Quote Link to post Share on other sites
Phil Posted March 11, 2015 Share Posted March 11, 2015 Almost sure I have the reciept here for them dude haha going to check later on :L Yep in full working order Just had new pads as says about! fantastic brakes no doubt, alot of fellas run them on evos etc. may well have been more expensive when purchased but im pretty sure a 6pot kits was 1150 new (couple of months back) still a great kit that i am sure will sell. Phil Quote Link to post Share on other sites
alexbennett Posted March 13, 2015 Author Share Posted March 13, 2015 Bump If these don't sell by the end of the month I'm putting them on my new one! Quote Link to post Share on other sites
