ashep91 Posted March 1, 2015 Posted March 1, 2015 Hi I am going to atempt removing the engine from my glanza ive seen theres a guide on gtt forum but that's for an ep82 is there much difference? Any tips? I was thinking of head removal then block to make it easier don't know if its the right way to go any advice would be good Quote
Jim* Posted March 1, 2015 Posted March 1, 2015 wouldn't bother taking the head off mate there's no point and it will end up costing you loads more for new head gasket and bolts too Quote
ashep91 Posted March 1, 2015 Author Posted March 1, 2015 Is it that easy? Did you label everything so you know what pipe goes where? Any guides for glanza on engine removal is it same as the gt guide on gtt forum Quote
Ollieh17 Posted March 1, 2015 Posted March 1, 2015 Yeh label everything, aslong as you know where to unplug everything its not that bad. If you arent confident though dont start. Will be very similar to a gt Quote
Charlie28 Posted March 4, 2015 Posted March 4, 2015 All electrics are more a less plug and play. Its very simple to remove a starlet engine. Quote
